ASROCK Mainboard AMD AM4 X570 Phantom Gaming-ITX/TB3
Mussa95
Hi guys,
I have bought an used Asrock Mainboard. Unfortunately the seller couldn't find the Wifi antenna any more. I have found a new one on ebay but I'm not sure, if it is the right one. Is someone here who can confirm that it is the right antenna with that specific part number? Thank you
Wifi Antenna
Pagusas
60
68
Those antenna's are standardized parts, you can interchange them/buy generic versions/use other mobo supplied ones. Its not something to worry about. Grab a cheap one on amazon and you'll be fine.
Something like this would be fine, unless you want that exact Asrock molded plastic for some reason.
Reactions: Mussa95
Mussa95
Thank you for your answer and recommendation. I think I can live without the Asrock plastic 🤣
