Hi! I'm building in a Dan A4, and are unsure how to set up my my fans. I have 2 available fan headers, and are connecting bottom case fan + pump head + radiator fan. I have set the pump to the CPU fan header, and use a splitter for the two other fans. Is this correct? Seems I can't control anyhting on PWM tho. Is this correct?
I also noticed that my PC turned off after some hours, and I suspect it might be due to the Corsair SF750 overheating. Would I be better off setting the radiator fan as exhaust?
Thanks!
Thanks!
