CPU AMD APU Raven readying for launch
TheHig
951
1,171
Cincinnati, Ohio
I assumed with a launch today that the 2200 and 2400 would be available................not a sign anywhere..... in UK at least
Here in the states it looks like the Egg has them at msrp +20 for the early adopter tax. 189 and 129. Amazon right in on launch price at 169 and 99 Prime shipping! Microcenter also at msrp but no sweet 30 dollar off a mobo combo yet.
Reactions: ChinStrap
K888D
1,483
2,970
UK
www.lazer3d.com
Just picked up a 2400G from the store with a Gigabyte B350 ITX motherboard.
Only thing I'm not sure about is whether it will boot without BIOS update and whether you can update the BIOS with the 2400G or you need a first gen chip inserted!?
Reactions: owliwar and TheHig
stree
307
178
Updated to 4,4 on X370 ITX.............now to see if I can get the RAM from 2400 to 2933.which is the native ram clock on the 2400 and 2200
All in readiness for when the 2400G gets dropped in..
Reactions: TheHig
ChinStrap
207
181
Looks like newegg has fixed their list price.
Reactions: TheHig and owliwar
Soul_Est
1,537
1,928
anyone else finds the 2200G the more interesting one? 60% of the price for 85% of the performance.
It's aways been that way. During the FM2+ generation, I preferred the A8-7600 vs the A10-78xxk. The question for me is how well do either the 2200G or 2400G OC and perform with a higher RAM OC?
TheHig
951
1,171
Cincinnati, Ohio
Very much yes! I think if one's plan is to go with a larger system that can squeeze in a dGPU in the future the 2400G is great since the 8 threads will be nice to have going forward for incremental upgrdes.
However, personally, I feel the 2200G is where its at for fire and forget brickless build with the HDPlex direct plug and 160w internal psu. You can go small and portable . I use Steam in home streaming from my main box all the time if whatever PC I have connected to the TV can't hang with a particular title. The 2200G sounds awesome for a portable fun box, kids pc, HTPC or light gamer daily driver on the cheap.
stree
307
178
No , not "broke", just something I do to draw out the passive aggressive. It works surprisingly well.
3,381
5,936
45
Victoria BC Canada
Get one of these badboys and all of your period key problems will cease:
Reactions: GuilleAcoustic
xcrco
111
84
I was about to jump the gun on these builds, but saw a video comparing a g4560 + 1030, and the 2400g is a bit behind when it comes to e sports gaming. Don't get me wrong it does play most of the games but for me buying new set of high frequency ram its not worth for the upgrade. I was really excited to cram this to have on the go low key gaming , but if it can run the same specs I have right now theres no reason for me :(
Reactions: TheHig
3,381
5,936
45
Victoria BC Canada
I think the salt in the wound on this whole thing is that AMD helped Intel do an APU that crushes the shit out of their offerings. I have absolutely no idea why they didn't make a 95W Raven Ridge part. Boggles my fucking mind.
EDIT: Case in point. If you look at power consumption on the 2200G it is around 45W with a peak of 57W. The 2400 runs at an average of 50W with peaks around 65W.
http://www.tomshardware.com/reviews/amd-ryzen-5-2400g-zen-vega-cpu-gpu,5467-5.html
Doing a wee bit of napkin math you can come to the conclusion that the power draw per Vega CU is somewhere around 2W. Adding 30W to the TDP budget would hypothetically allow them to add 15 cores to the 11 already on the 2400G for a total of 26. This is two more Vega CUs (8% more) than on the Hades Canyon chip which exceeds the performance of the RX 570 and maybe even the RX 580. What the actual fuck AMD letting Intel cannabalize your entire lower end GPU market and then not taking a piece of the action for yourself. :mad:
Zackmd1
347
561
Maryland
What ever happened to the rumored AMD Fenghuang APU with 28 Vega CU?
https://wccftech.com/amd-fenghuang-desktop-apu-with-15ff-28-cu-graphics/
My assumption if this even existed is that it would be an X399 socket CPU as I do not see them being able to fit all of those CUs and HBM2 memory on a die that could fit in AM4 unless the 2GB listed was system memory and not dedicated memory.
An APU with the GPU performance at or slightly over a 1050 ti and a TDP of 95 watts would be perfect in my book. Enough for 1080p 60FPS gaming at mostly high settings.
Reactions: Soul_Est
TheHig
951
1,171
Cincinnati, Ohio
Yeah seeing what is possible as far as Hades Canyon is concerned has me wishing for a Ryzen/Vega/Hbm2 franken chip too. BUT Hades Canyon isn’t going to be 99-169 bucks. I can’t imagine it being as cheap as a full RyzenG build even with the insanity of DDR4 prices. Different performance tiers. If it is then yeah AMD screwed the pooch getting in bed with Intel.
Looking at RAM price, I see no point in replacing my i7-4785T (25W with iGPU disabled) and my GT1030. This is still promising for future iterations
Definitely not going to pull people off of decent performing low power builds. But building new I see the appeal. I mean used price performance low wattage is a Haswell S cpu,ddr3, chreap board used 750ti/1030 all day.
Reactions: Soul_Est and xcrco
