D
DelUser6216
Guest
Ooh yes, the case...
I'm really taking it one step at a time with my build, I started with scrap wood (lol), then on to MXF particle board (current case), and now acrylic and I hope in the future that I could create my case out of aluminum/steel or ABS. I also desire to use Parvum's Modding Cubes to create a very very modular hotswap build. Then I'll spray paint the acrylic to make the case look better.
I had my first feel of acrylic sheets and acquired a sample recently so these questions are in the context of if I go to home depot and scratch build my own case, drill the fan holes and screws whatnot, file the vents. What specific type or brand of acrylic should I be looking for? We're talking easy to handle 1-3mm. And through all of this, how should I cut the acrylic? A boxcutter and karate chop? Or should I just dial it up to table saw?
And then there's custom made acrylic pieces you can get. I've heard of TAP Plastics, and I assume that someone here or another place sourced acrylic from them, is there anything else like that manufacturer? I can't find anything... but I definitely have the budget for a case in this manner.
Are these places good to start? Yeah there's some fundamentals to understand.
http://www.bit-tech.net/guides/modding/a_modders_guide_to_acrylic/1/
https://gizmodo.com/5922506/everything-you-need-to-make-kick-ass-custom-case-mods
