Hello all!
So I always look at mini-itx cases nowadays and think, "huh, those are nice and small, but if I buy a mini-itx graphics card, that's a considerable amount of space going to waste."
On the other hand, there's really no good way to optimize that space, because let's say the mobo, GPU, and PSU are all "boxes"... well, there is no optimal space setup for three boxes; whereas, if the GPU is full-length (two "boxes"), then two main optimal designs manifest: the layout of the A4-SFX, and that of the Node 202.
But there has to be a way, I thought. So which of the other two "boxes" could change? The power supply, surely! What power supply is high enough power, but not a "box" at all? Why, Flex ATX!
Introducing the smallest by volume gaming rig that can house, and power, a GTX 1070 no problem:
I won't take a ton of time explaining the design, as I'm sure most of you are very astute when it comes to these things.
Now, the only thing I don't have included in the drawing is a mounting for the PCIe riser cable. I'm not 100% sure on the measurements there, so I'll add when needed. Also not shown is a wraparound top/sides panel, fully vented and hopefully fully filtered, at least on the sides.
Anyways, the one 2.5" drive is shown in red, and everything else is pretty darn obvious as to where it goes.
Thoughts? Advice? Shade to be thrown?
Thanks in advance!
Thanks in advance!
