Our discussions with @Tossy gave me the motivation to finish this long overdue project :
to use a Thermalright Shaman I bought for 15€ to cool an Intel CPU.
After two hours of measuring, drilling and cutting some exsting aluminium and copper pieces, I obtained a working 40 mm high top-down LGA 115X cooler !
I had to orient the heatsink this way to avoid some capacitors around the socket.
Total height without fans is 52 mm from the bottom case panel to the top of the cooler.
With a 15 mm 140mm fan, total height is 70 mm.
With a 12 mm 120mm fan, total height would be 64 mm !
Otherwise, by just making a new plate, I'll be able to rotate the cooler by 90° and stay within the 170 x 170 footprint of the mobo !!
Please note that I used a thin Mini-ITX board as the clearance under the cooler is pretty low.
On mini-ITX boards, you will need VLP dimms most likely and a 24-Pin extension for your PicoPSU.
It looks badass and it works great on a G4560 !
Some temps after 45 min of Prime95 on both cores (ambiant temp is 22°c) :
- With a Prolimatech slim 140 mm fan @800RPM, temprature stabilises around 45°.
- Run fanless, temperature stabilises around 75°.
