Hi Gents!
Thanks to this forum and this thread in particular I have cooked me an x600 mini instead of and old HP Elitedesk 800 G1 mini
I have basically followed the recipe from this thread and here is what I have:
X600 mini stock bios 2.03
Ryzen 8700G
2x16Gb Kingston Fury Impact KF564S38IB-16 that run on it's native 6400 from XMP profile selected in BIOS
AXP90-X47 FULL with stock fan
Arctic Cooling MX-4 thermal interface
Intel WiFi 9260 AC
Kingston A2000 SSD
Stock AsRock PSU
All stock i.e. no overclocking except CPU Curve optimizer set all cores -40 in BIOS.
+USB2.0 board and rear audio jack from Ali
And in reality I'm fully happy with the build but 2 points below so I would be more than grateful for comments and directions on where to dig:
1. Temps. It keeps around 40C idle and when I run a stress test it gets to the 90C in around 1 minute and 20 seconds and stays at this temp forever. It does drop the CPU power from around 86W to 81W and that is it. Fully stable here, no throttling according to the monitoring tools (OCCT).
I double checked the CPU-to-Radiator footprint and it is absolutely OK (20+ years of experience with computers), the fan profile is to Standard so I do hear it spins up and the monitoring confirms this.
So the question here i have - is this normal behavior? I expected lower temps on this CPU-cooler pair or am I wrong?
2. Fan noise. The Thermalright stock fan is noisy... and still noisy at CPU temp 40C where BIOS keeps it at 1700rpm. Do i need to update BIOS for more aggressive FAN speed adjustments or something else?
My future plans are:
1. Install memory heatsinks (came from Ali, same as mentioned in this thread), btw, those who istalled ram heatsinks, did you use stock thermal adhesive or replaced with something, why I am asking is because the chip in a middle (SPD I believe) is around 0,5 mm higher that memory chips so the heatsink will not go straight forward..
2. memory overclock, to maximizethe iGPU performance
3. Install 120mm fan, I've bought the Silverstone Air Slimmer 120 and it fits basically same way as the Thermalrigt stock fan, but thinking of some nice way to mount it. I remember somebody mentioned about 120mm fan in x600 mini but can not find the post.
4. Install 2x40mm fans to improve hot air exhaustto the perforated side of the mini's case, ordered 2 noctua 40x10mm PWM fans.
So i apologize for long post, but it's kinda introduction + questions: 2 in one![]()
Thanks for your advise. Actually I have already played with the limits in BIOS and also found that even 54W +Curve Optimizer (all cores -47) gives nearly zero performance drop in games and real app use-cases, but keep the temps much lower like ~70-75C at stress tests while fully stable. So i'll leave this as is for now. Why i made my post is i first thought my cooler might be defective or something, but now i see this should be ok.limiting the power consumption to 65W
Yes, now i managed to get it work (it's not obvious on how to adjust it) and have it silent at office loads, will make some further tests on 120mm fan so will see, thanks anyway.fan speed curve, the deskmini x600 BIOS has a decent fan curve editor,
I would try to avoid using thermal pads between the ram and the heatsinks. The SPD chip doesn't need to be cooled so I would drill a hole in the ram heatsinks where the SPD chip would collide so you can fully seat them using the stock thermal tape. That would transfer heat much better than any thermal pad.Thanks for your advise. Actually I have already played with the limits in BIOS and also found that even 54W +Curve Optimizer (all cores -47) gives nearly zero performance drop in games and real app use-cases, but keep the temps much lower like ~70-75C at stress tests while fully stable. So i'll leave this as is for now. Why i made my post is i first thought my cooler might be defective or something, but now i see this should be ok.
So besides the real experience of the AXP90-X47 FULL users in x600 Mini, I am really interested on howto mount RAM heatsinks, maybe somebody could share some experience. What i think now is to have 1mm thermal pads for memory chips and 0,5mm for that high SPD chip for one side and 0,5mm thermal pads for the backside of the modules since it's flat and fix them with a kind of black paperclip (aka binder clip).
more then welcome to help test things out. I'm using the stock thermalright fan, blowing down on the cooler as it came out of fhe box. the fans I'll be adding should be pulling air out, haven't decided yet whether to add 4 pull fans, 1 push and 2 pull or just 2 pull. probably down the line I'll be testing the noctua swap, by consulting some db-nornalized tests the thermalright is superior to the noctua in terms of cooling, but the noctua fan is better if you temp-normalize the chart.Thanks for sharing this useful info, what fan do you use here for cpu cooler and does it blow in or out?
PS. I will definitely give it a try and post results here, just need to find some time.
Just embrace open case cooling and go bigSo i did some tests comparing vertical vs horizontal positioning of the cooler. I noticed that the number of holes on the top panel of x600 is nearly same to back side, so run OCCT stress test and after temps got stable, i just rotated the whole mini 90degrees to make it stand on front panel. I made this test many times actually having compared 2 FANs: stock and Silverstone Air Slimmer 120 in two positions (blowing in (stock position) and out - the Slimmer was not tested to blow out as fan is blocked from spinning in this position). All tests made with Silent fan preset in BIOS, 54w and 65w power limit and CO -45 all cores.
As a result,
Stock fan:
Silverstone Air Slimmer 120 (AS120), blows in:
- blow in vs blow out : -2 degrees when blows out
- blow in, stock oriented (heatsink fins horizontal) vs face down (heatsing fins vertival) : -2 degrees when fins vertical
- blow out, stock oriented (heatsink fins horizontal) vs face down (heatsing fins vertival) : no difference
- RAM (naked, no additional heatsinks) temp - +-1 degree, same temp
So from this test I decided that untill I stay in stock case I will stay with stock fan blowing out, with stock CPU cooler heatsing orintation.
- AS120 vs stock fan blows out : +5-6 degrees with AS120
that was my hope to improve cooling.
- AS120 blows in horizontal vs vertical : -3 degrees when fins vertical
- RAM (naked, no additional heatsinks) temp AS120 blows in vs stock fan : -4-5 degrees with AS120
It's pity that the 120mm Silverstone fan didn't give any reduction in CPU temp (it's actually more noisy compared to stock one), being at the same time the best slim 120mm fan in terms of perfomance (CFM and pressure).
My next test would be to put 2 40mm noctua fans (arrived today) on the x600 top panel, but it looks like that to do this i will need to do something with VRM heatsink as otherwise fans will not fit. And will probably try to find a bettter 92mm slim fan, but according to the SFF Master list the stock fan of the x47 is not too bad and fan swap will probably not give any CPU temp drop or acoustic confort at high load.
I will leave it alone for now with stock fan, blows out, 54W power limit and CurveOptimizer -45 all cores with FAN curve adjusted to have 72-73C at stress (OCCT) test and around 45C idle but silent.
(more pictures: https://smallformfactor.net/forum/threads/asrock’s-x600-deskmini-–-finally-–-again.19619/post-290101)
Stress test at 65W plus 6W each RAM dimm (2x32GB 7600 MT/s double sided) with fan spinning at 600 RPM = 60ºC CPU, 60ºC VRM, 53ºC RAM dead silent
I didn't peal off the stock ram stickers because I'd void the warranty otherwise, but they're so thin that I guess temperatures aren't affected more than a couple of degrees based on what I've been able to measure with a thermocouple.I have a question, when you installed the RAM heatsinks, have you pealed off stock ram stickers to apply heatsink straight to the chip? And how's the 3m tape, holds good so far? If you took them away, was it hard, are they glued well i.e. what's the best way to remove them without damaging ram chips?
I understand better nowI didn't peal off the stock ram stickers because I'd void the warranty otherwise, but they're so thin that I guess temperatures aren't affected more than a couple of degrees based on what I've been able to measure with a thermocouple.
The 3M tape is holding as new, I guess it's because it is specifically designed for this application (heat transfer tape instead of heat resistant tape) and because the heatsinks are very light compared to what they can hold. I even had to remove them a couple of times and I've been able to reuse the tape without loosing cooling performance or stickiness. To do that the best way I found is to push and twist instead of pulling to prevent ripping off the chips. It requires quite a lot of force but since you're not pulling I'd assume it is safe to do it, didn't have any problem so far.
I have the feeling that the difference in temperatures comes from me using 2x32GB dimms vs your 2x16GB dimms, which should result in more power consumption. Could you please check the power consumption of each of your dimms using hwinfo while running for example Furmark? I've always wondered how much 16GB dimms at 8000 MT/s consume. I also run my sticks at 1.43v. Thank you in advance!I understand better nowwhy you get higher RAM temperatures than me, because of course these stickers have a significant impact on the thermal transfer to your heatsinks (I didn't ask the question at the time because I logically thought that you would have removed them to maximize the efficiency of your heatsinks), so I put in mind your high temperatures on the fact that your heatsinks are made of aluminum unlike mine which are made of copper (I also told myself that the thermal glue of your adhesive was perhaps less good too), but sincerely if you removed the original stickers, even if it is at the expense of a loss of warranty (the last time I saw RAM being damaged and dying little by little because of overclocking, and especially overvoltage was at the time of the DDR1 generation) then you could reduce your maximum temperatures by between 10 and 15°C easily, personally I am on Kingston 32GB (2x16) 6400MHz CL38 overclocked to 8000MHz CL38 (and optimized subtimings) under 1.43v in a 3D printed case with a 120mm fan (15mm thick) that can go up to 72cfm (with a pretty good static pressure) and a Thermalright AXP90-X53 Full Cooper CPU heatsink that barely hinders the airflow to the RAM and they have never exceeded 45°C so far.
I ran a little over 30 minutes of Furmark2 (the latest version is v2.7.0.0) in CPUBurner mode. I got 6.625 Watts (at maximum) on each stick in "Total Power." The VDD (SWA) of each varied between 1.390V (min) and 1.450V (max) depending on the load level, for an average of 1.434V (measured from the start to the end of the test). I reached a maximum of 44°C (SPD Hub Temp) for the hottest stick (closest to the CPU). Afterwards, I was in a room where the ambient temperature varied between 18 and 20°C depending on the time of day (during the test, the ambient temperature varied between 19 and 19.5°C).
There you go, I hope you have the information you wanted, and if not, I apologize for forgetting that you were using Dual-Sided on your two 32GB RAM sticks. It's much harder to cool than Single-Sided sticks, I agree. But I maintain that I'm sure that you would lose at least 5°C if you had removed the original stickers beforehand (the heat transfer to your heat sinks would be much better).
Running OCCT, HWinfo reports around 15% increase in memory power consumption compared to Furmark, so it is definitely stressing more the memory and it is sustained power consumption (as furmark). I'll switch to OCCT to test memory cooling performance in the future.Gents, your tests are very useful I believe, and very interesting to read. I can just add that i have tested my ram (2х16 Impact fury 6400 cl38 stock) with no heatsinks with OCCT ram stress test and temps easily reach out 75c fairly quickly and stay there +-2C. So it would be very interesting to see the results if you could test your ram with heatsinks with this tool, as to me it makes more intensive load than furmark.
I recommend you to install HWInfo and share your idle stats (all of them) with both RAM speeds to see if we can spot the culpritGents, can you explain me one thing please. Playing with my x600 i noticed that if i set the RAM speed to it's native 6400 by selecting the apropriate profile in BIOS i get my CPU idle at ~45C, but if i just change the ram profile to 4800 - the CPU gets down to ~34-35C idle. No more changes, just pick another profile for RAM in BIOS. Same difference under load in stress tests.. I Have the 8700G and quite surprised with such behaviour...
