I lost hope that small graphics cards will come back any time soon, so I started looking for an air cooled case that supports the enormous graphics cards that are on the market or soon to be and also, one that fit the enormous CPU air coolers as well. I was disappointed in the cases I have found so far.
Here are the things I was looking for:
For reference, the dimensions are 220mm x 185mm x 332mm.
GPU is 327mm long and 141mm tall. 3 slots wide
case fan is 140mm.
let me know what you think, or even better, if anybody is already making this.
- minimal desk footprint - GPU in vertical orientation
- space for big air coolers - noctua nh-D15, Be Quiet! Dark Rock Pro, Scythe Fuma 2 etc.
- space for big 3-slot GPUs
- windowed side panel to show off the components
- airflow and ventilation to feed the big coolers
case fan is 140mm.
