CPU 10700K low performance?
tinyitx
2,279
2,338
I have an 10700K (stock) in a MSI Z490I Unify (with 2x16GB DDR4-3600, GTX 780Ti). The mobo has latest BIOS as of today.
Everything in the BIOS is default except XMP is enabled for the memory. (CPU cooling is set as 'Tower-Air' which has the same 255W as 'Water-cooler')
I ran a couple CPU benchmarks.
For CPU-Z: single is 583 and multi is 5448
For Cinebench R20: single is 504 and multi is 4400.
Do they look like a stock 10700K? I tried to find some scores for comparison but it seems most people only provide overclocked result.
For a few that I can find, it seems my scores are a little low.
Since these are CPU benchmark, I think the relatively 'weak' 780Ti cannot be the reason?
Or, are there some settings that I should check in the BIOS?
BTW, temp is OK. It is 69-72C during benchmarking.
Thanks for any input.
2,602
2,717
I don't have a 10700k so I can't compare directly but those scores don't look bad. My 8700k at 5.0 GHz was only able to run 3885 multi. At stock it ran multi 3384 and single 441, so you beat those scores handily.
Reactions: tinyitx
supremesff
Hi, I also have the I7 10700K, my Cinebench R20 Score is around 4876 (Undervolted, stock, temps around 80-92 at 100% usage using the Silverstone Raven Z RVZ02 case).
Is my first SFF build, the CPU temps aren't good (using Cryorig C7 Cu Full Copper cooler with Arctic MX-2 thermal paste, soon arriving the Grizzly Kryo one for better temps) hopefully I will be able to get them to a lower level.
