I recently put together a sff build but had a few questions after running some benchmarks. Currently using the integrated graphics while I wait for a price drop on the GPU.
Specs
Windows 11
Intel i5 13600K
Asrock Z790m-itx
CORSAIR Vengeance DDR5 32GB 5600
Crucial P5 Plus 2TB
NZXT H1 V2 modified using Noctua fan for the exhaust and radiator
I ran CPU-Z and got a score of 406.7 for CPU single and 6590.6 for CPU Multi. The scores seems fairly low on the comparison graphs. I also ran Cinebench R23 and got a CPU Multi score of about 15647. My cpu temps are hovering around 83C when running Cinebench. I did noticed that for some reason, the CPU speed on the task manager doesn't go above 3.05GHz; I thought the CPU could boost to around 5.1GHZ
I've updated all the drivers to the latest versions and I'm also running the default settings in the bios (expected for enabling XMP).
I have not experienced any random shutdown but was just curious to see why the scores are so low. Should I be concerned about the benchmarking scores?
Thanks
Specs
Windows 11
Intel i5 13600K
Asrock Z790m-itx
Crucial P5 Plus 2TB
Thanks
