I bought this type of cable to make a custom cable for my SF750 power supply, with a length of around 30cm or less. However, I'm not very familiar with the cable size conversion chart, so I ended up buying the 0.75sq type. Based on what I found, it's approximately 19AWG.
This cable is rated at 600V and can withstand temperatures up to 300 degrees.
I'm wondering if it's safe to use for making custom cables? If not, should I get a different size, like 1sq or 18AWG?
Thank you for the advice.
