Ultra Low Profile G1/8 Port Module for Corsair Hydro XG7 3080 and 3090FE
.STEP Ultra Low Profile G1/8 Port Module for Corsair Hydro XG7 3080 and 3090FE 16
A custom and ultra low profile port module for machining in aluminum or acetal designed for my S4Max build - details, photos of the finished part machined in aluminum and context in my build log here.
Key features:
- Designed for minimum viable bounding box volume
- Designed for compact Festo G1/8 fittings
- Designed to work with the original o-rings coming with the Corsair Hydro XG7
- Adding a second direction for both inlet and outlet ports, allowing for connections parallel to the PCB plane
- Designed to stay fully within the projection/ height of the Corsair Hydro XG7 3080 FE - including Festo G1/8 fittings to not intersect with the PCB plane - essentially allowing for the more compact 3080FE version of the Corsair HydroX to be used on a 3090FE
- Tried and tested - works!
- Requires attachment screws different form those included with the Corsair block - check the build log for specs
- Includes two versions of the model - one with and one without countersunk threads, as, depending on manufacturing process, the threads may be cut after CNC machining the piece
Author
petricor
Downloads
Views
1,116
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from petricor
