Enclosure ZS-A4S V3 - Sweet size for compact mid-spec air cooled build
mueh
hi, may i know, does this case support normal flex psu? or its only support 1u flex psu?
prayogahs
208
272
It supports the standard Flex ATX PSU of 150x81.5x40.5mm and should be able to support up to 170mm length with vertical modular connectors, not sure if GEEEK modular Flex PSUs will fit though. 1U PSUs are not standard and can be much longer or wider than Flex ATX PSUs, while keeping the 40.5mm (1U) height.
Reactions: ZS-Cases
