Hi Community,
First post here, as well as first SFF Modding project. I recently snagged an Inwin Chopin and was looking to do an APU build. I got curious this morning about the Zotac 1060 Mini I had laying around and decided to see if I could fit it in the back side of the case.
My thinking here is that if you can get another mesh panel that is on the MOBO side you might be able to get the GPU to fit.
The Zotac 1060 nearly fits on the back side being too long by about 2mm. The primary reason it can't fit in I believe is because of the DVI port. Which leads to my first question, is it possible to remove the DVI port from this board?
My second question is about modding the heatsink/fan. As you would guess removing the fan shroud gives a bit more clearance, however I still need it slimmed down by about 3-5mm to be able to get the Mesh panel on. If anyone has some sage advice about modding these two elements it would be much appreciated. I assume it would be possible to replace the heatsink and fan, similar to the Chopin/1050 Ti project I saw not too long ago. If anyone could point me in the right direction it would be much appreciated.
I have photos here:
Cheers!
-goose
I have photos here:
Cheers!
-goose
