Hi Folks,
Finished my A4 build with a 2060 Super and happened to get my hands on a Zotac 3070 AMP Holo which is a large card, unlike the Twin cards which whilst looking similar are really much smaller..
Question from a n00b - given that this card is tall and wide, the top metal frame which ive removed is blocked by the vertical lip - which i could remove by grinder but that would likely compremise the clip holder.
Does anyone have an idea about how a replacement for the top section could be fashioned, perhaps so that could stepped outward - note that i've looked into spacers but the issue isnt the side panel.
Thanks in advance,
Thanks in advance,
