Source: TechPowerup, Reddit, Bilibili, VideoCardz
As large as they are, ASUS’s ProArt GPUs are pretty premium looking – no flashyness, just smooth lines and subtle design cues. Chassis designer Xiikii Industry has taken these design cues, and designed a chassis around this GPU series, and it measures in at only 9.8L – 300 x 120 x 50 mm.
This schmick looking, all-black chassis, is designed to deftly match the GPUs curves, angles and dimensions, leading to a pretty seamless look. Included with the chassis is a PCIe 4.0 riser cable, special power supply cabling (no mention of power supply...
Continue reading...
b00zled
I'd grab one if I had the cash to burn. Then once I upgraded, set it up on a display shelf. It's like (truly) modern art.
Reactions: WPD
Kreasu
Is this the same size as the 4090? I know it’s using the pro art 4080 I wonder how they got the power cable in so thin like that.
