Motherboard X570 ITX Motherboard Review Thread.
scatterforce
411
325
I want to know if it will run with the fan unplugged..... I'd rather drop a beefy M.2 heat spreader and use the CPU cooler for air flow.
huddy
30
29
I ordered the gigabyteboard today. Might as well future proof and ASUS wasn't ready. I liked the Asrock board too but didn't want to be stuck with only 1x m.2 slot
2,669
2,793
Those were my thoughts too. I thought about going with the MSI B450 but my build won't have any SATA drives and I needed the 2nd M.2 slot.
TheHig
951
1,171
Local Microcenter had only a few Aorus 570 itx boards. Sold out very quickly... What about the Asus B450i and the 3700x or even 3600? Has the 2 m.2 slots at least.
scatterforce
411
325
The limitations with the ASUS B450i and X470i boards are that if you occupy the rear m.2 slot, your GPU is limited to x8 instead of x16...... if you have a midrange GPU, it won't matter much. If you are planning to use a 2080 or higher, you will lose some fps. The new 2070 Super might also be hampered by x8, now that it's using a TU104 die.
TheHig
951
1,171
True. Ran the CH7 and same deal. Glad you mentioned it though as I totally forgot about it.
smitty2k1
978
500
wait what? is this a ryzen 3xxx issue? My ASRock B450 is happy with a M.2, GPU, and 2xxx series CPU.
TheHig
951
1,171
@scatterforce is referring to B450 and X470 boards that have 2 m.2 slots. If both drive slots are populated it takes bandwidth away from your PCIE x16 (GPU) slot. This is a chipset limitation I believe. So x570 does not do that then? Also the AsRock B450 has just the one m.2 slot and full x16 to the GPU slot. ( have one myself)
TheHig
951
1,171
Interesting for sure. Still the 2700x on x470 still draws more power than the 3700x on x570 in those graphs. Agree that more power and heat are obv the enemy of SFF
OtackKulandinglar
46
76
Looks like X570 is a real power hog
Woof, may go for B450 after all. Still waiting on the case so I suppose I'm in no rush to decide. Save money and thermals on the board and just put it into a binned 3800X... Hodlgang!
Reactions: scatterforce
quetzacoatlx
103
62
De8aur tested the power consumption of the X570 chipset. It is below 10w, so a relatively large heatsink with passive cooling should be enough in theory.
smitty2k1
978
500
Ahhh I misread ASUS = ASRock.
Two M.2 ports makes sense.
scatterforce
411
325
As soon as someone gets the Gigabyte X570 ITX, could you please post pictures of the M.2 drive installation process? I'd like to see the board without the included heatsink/fan mounted. I've been searching but have found nothing.
Bioforce
251
116
Could anyone clarify how many fan headers are available on the Gigabyte board? The advertising says 1 CPU fan header and 2 case fan headers, but people in other threads are saying there's actually only 1 case fan header as one of the "two" is dedicated to the chipset fan.
Legion
364
402
Yep, this is it. one CPU and two case fan headers (one of which the chipset / NVME cooler uses)
I don't see that as an issue or limitation with PWM splitters or hubs easily available if you need more.
Reactions: Bioforce
Bioforce
251
116
That's honestly pretty disingenuous of them to say it has 3 headers when one is dedicated to an integral part of the board. It's not hugely problematic, but seeing as I'll have 4 fans in my next build I'd like to be able to individually control the top 2 and bottom 2 fans while also having an AIO pump plugged in. I suppose if I wanted I could just plug the AIO directly to the PSU since it only runs at one speed (12V) anyway.
Is there a general consensus as to which ITX board looks the best? Buildzoid had a lot of good things to say about the VRM on the Gigabyte board, but I haven't heard anything about the others.
