I'm planning to use the same configuration as the "Parametric Case".
Noctua fans are really expensive in my country, so I'd like to know If the 120mm would perform well in the following configuration, so I don't have to buy the 140mm, considering It would be difficult to adapt the 140mm in another case (in case I decide to change).
Thank you for your help and attention.
I'm sorry for all the inconvenience.
