The front of my case is an 2mm aluminum panel with a usb port. I would like to mount a piece of acrylic in there that is flush with the front. (Similarly to what Streacom does with their IR ports).
What would be the best way to do this? Get a 3mm piece of acrylic in the dimensions of the USB port and wedge it in? Or in the same dimensions but 1mm wider, melt the edges, and wedge it in?
