Hey all,
First post! Sharing my first custom watercooled system.
It's a WIP since I ran out of fittings and am currently waiting for some more, but here's the progress so far.
If you're wondering where the branding on my Eisbaer LT is, I had to peel it off cause my pump broke (or so I thought) so I had to replace it.
Parts List:
- Louqe Ghost S1
- Ryzen 3950x
- Nvidia GTX 2080 Super
- Asus B450 itx
- Timetec 32gb ram
- Corsair SF600
- Samsung Evo nvme ssd 500gb
- Alphacool Eisbaer LT CPU waterblock pump combo
- Alphacool Eisblock ES Acetal GPU waterblock
- Alphacool NexXxos St30 240mm v2 radiator
- Alphacool Eisflugel Flow meter (being used as a reservoir)
- Alphacool TPV tubing
- Alphacool TPV fittings (rotary 90, straight metal, quick release)
Todo:
- Add GPU to the loop (thank god for quick release fittings)
- Add RGB Ram
- Add RGB fans for some illumination from the top
Parts List:
- Louqe Ghost S1
- Ryzen 3950x
- Asus B450 itx
- Timetec 32gb ram
- Corsair SF600
Todo:
- Add RGB Ram
