Hey guys! Will it leak if I put a 1/4" ID soft tube onto a 1/4" OD straight copper tube, and clamp it down with a hose clamp?
I need to do some modification to my radiator, which involves in cutting off the barbed part of the included fittings:
They are way too tall so they need to come off I'm not sure if clamping the tubbing down is good enough thou.
