New to wc and want to sanity check my loop plan. I am building a new rig in a sliger sm570 with the following:
- Ryzen 3900x
- EVGA Hydro Copper 2080 Super
- Asus Rog B550i
- Sabrent Rocket 1TB
- G. Skill Ripjaws 2x16
- EK xtop DDC 3.2
- Corsair SF750
- 4x Noctua NF-A12x15 chromax
Fittings are TBD, but it looks like I will need the following:
- 6x 90 deg
- 1 low profile 90 deg, i have read that Koolance is the lowest profile 90 deg (this is to connect the res to pump as clearance is < 25mm)
- 1 1/4" male to female connector (it doesn't look like the Koolance LP has a male end to screw in)
- 6x straight compression fittings
I am going to use 3/8 x 5/8 soft tubing for this build as well as XSPC TX240 rads (which are out of stock everywhere, but i will wait because they are the only rads that will fit in the bottom of the case)
Does this loop set up make sense? All comments/suggestions are welcome.
- Ryzen 3900x
- Asus Rog B550i
- EK xtop DDC 3.2
- Corsair SF750
- 6x 90 deg
