If I consider this with the 300W extention AC-DC, will it be enough to power my system, My system consist of the following.
M1 N case
Silverstone SX700PLT
Gigabyte GA-AB350N-Gaming WIFI m-ITX
AMD Ryzen 1600 CPU
AMD Radeon Pro WX3100 workstation GPU (no external power connectors is needed, upto 50w power, avarage 40w power)
2 X 8GB 16GB Gskill Trident RGB Z AMD Ryzen edition
512GB 950 pro M.2
2 4TB 3.5 enterprise edition HDD
1 6TB 3.5 enterprise edition HDD
3.2w motor pump for water cooling none PWM and is always on(connected to CPU header)
2 EK varder evo Fan using PWM (one for case connect to the system header, and one for the Radiator connected to CPU header with splitter, at times the Fan does not spin because it has not reached the temp and workload)
This is my present system, if I decide on a smaller case or the present case, I can also use air cooling instead, the current PSU is kind of tight and big, so i'm considering this HDPlex 400w HiFi DC-ATX , I only use my PC for BT downloading, internet browsing and watching film. At present, my PSU has never had the Fan spinning yet, the system has been used for about one month now.
CPU temp is average at 35-38c
System temp average at 35c
Chipset temp Average at 55c
Hope the information provided can help.
M1 N case
AMD Ryzen 1600 CPU
512GB 950 pro M.2
