In the past it was easy. If you used Intel CPUs/Sockets, you chose the NH-L9i. If you had AMD, you chose the L9a.
But now Noctua confuses me, with their upgrade package: http://noctua.at/en/noctua-offers-free-am4-upgrade-kit-for-nh-l9a-and-nh-l9i-low-profile-coolers
It seems like it suddenly is possible to mount either a L9i OR L9a onto AM4 with this new bracket. First of all I don't understand how that is possible. Second of all, if I own neither of the coolers at the moment, which one should I go for?
Will the new AM4-bracket make the cooler taller than before?
Planning on using an NH-L9x with AM4 ITX-mobo in a case with about 4 cm clearance.
