Where to get a custom radiator?
Biowarejak
Maker of Awesome | User 1615
1,744
2,262
^This. I too would like to know for future reference if anyone has that kind of manufacturing capability. But what size are you looking for OP?
Reactions: SeñorDonut
wywywywy
272
219
I wanted a copper slim 92mm radiator for a SFF build, but there's none available so I googled the same question.
I only found a couple of none-answers saying that it'll be v v expensive if such a service was offered.
So anyway please let us know when/if you've managed to find one.
wywywywy
272
219
I watched a youtube on how they're made (because I thought about diying one too), and it seemed v v difficult!
SeñorDonut
the
501
454
I am looking for a 3x60mm rad with a rather abnormal connection placement. IIRC, @QinX got a custom 2x40mm rad made where he works, or was that just the CPU and GPU blocks?
SeñorDonut
the
501
454
Update: image
Biowarejak
1,744
2,262
That's helpful! After work I'm going to get the materials I need but I have a dual 80mm that I've got designed already.
How thick is that rad? o_O
SeñorDonut
the
501
454
It's 54mm thick, but I'm fine with it being more or less.
Wait, are you actually going to build this?
Biowarejak
1,744
2,262
I'm building mine first to test if it's feasible, I'm not sure how it will turn out. If it's acceptable then I'm sure I'd be willing to give yours a shot
Reactions: Phryq
Biowarejak
1,744
2,262
Probably on par with some of the commercial options out there. It would probably have less cooling capacity but it would be custom built so I'm not sure the proper value to assign to it.
Ceros_X
748
660
@QinX had a custom radiator built, iirc, but he also had some industry contacts. Might be able to shed some light on the subject!
