Custom Watercooling Radiator / Block
BryceK
143
86
Hi Guys,
So I want to get a custom Radiator made for watercooling and a GPU specific block. Does anyone know a company that specializes in this?
Cheers
AleksandarK
/dev/null
May 14, 2017
703
773
You can contact Alphacool to get custom radiator, but it will cost you 80,000 USD! It is because of the high costs for their machines. I think that HardwareLabs may help out. If not, try to find some radiator maker for cars, trucks etc. that make copper radiators. They will be able to do a custom model for you.
As far as GPU block, you can contact Alphacool too. You need to send them a GPU and they will provide a block free of charge. But only downside will be their dual slot design.
BryceK
143
86
@AleksandarK , @|||, Thanks for the quick response :)
I think the 80K at AlphaCool is kinda much since it would only be 2 prototypes and for the water block I would prefer are more open block so you see the liquid flow through it.
I will also check HardwareLabs and see what is possible, since the Radiator needs to be a AIO.
Cheers
