CPU Where can I buy a case-mounted plug for a custom internal-PSU case project?
Damprol
I need one of these things. What's the correct terminology for it and where can I buy one?
701
Whereabouts in the world are you located? Major electronics suppliers and local parts stores should be able to supply these, search for IEC C14 panel mount.
Please be extremely careful playing with 110/240V electricity, make sure you safely ground any conductive equipment/chassis and double/triple check wiring and switches before touching anything! 👍
Best of luck
Reactions: Phuncz and Damprol
