were do you find a cheap dremmal?
metropath27
77
I've been looking for a dremal to cut part of the heatsink on my graghics card but there expensive like 30$ to 80 do you guys know of any cheap ones preferably under 25$? i couldnt find any that would be able to cut a heatsink
Thestarkiller32
152
102
https://www.lidl.de/de/parkside-akk...9Yx1P104qnIiSlKnL39dgPaUJ-t4EWKhoCHKYQAvD_BwE
In my Contry, thats an Option that you could considure :)
thewizzard1
334
251
Just use jeweler's saw if it's a small / medium job. You can get those very cheap on Ebay, and they are very effective and easy to use.
If it's more than 1/4" thick or more than 5", use a hand saw with a metal cutting blade. Copper and aluminum are very soft, not hard to cut by hand.
BrotherStein
168
136
I just picked this one up off of Amazon for $20 bucks. It gets the job done. I'm not sure how long it will hold up, but it has performed well. I had to cut and mod an internal brick for a build.
