Edit: Nevermind I just tried to fit it and it's too wide! ?
Hi all,
Just got a cheap second-hand/nearly new
Alphacool Eisblock Aurora Plexi GPX-N RTX 2080
for my 2080 Super and it's huge. Does this fit in the Ncase and any advice on how to get something almost the same foot print inside? Thanks
Technical specifications:
Hi all,
- W x D x H: 141 x 290 x 25.3 mm
- Net weight: 775 g
- Maximum working temperature: 60 ° C
- Material cooler: nickel-plated copper
- Material lid: plexiglass
- Thickness of the cooling fins: 0.6 mm
- Connections: 4 x G1 / 4 "
- Power connection digital RGB: 3-pin 5V (0.5A)
- Pressure tested: 1.5 bar
