So there are plenty of people (including Myself) who you can go to to buy fully customizable handmade cables for your PC but if you want to DIY it, this Thread should serve as the absolute Basic Intro to custom cable creation.
The Tools You'll Need...
Tooling Budget = $110 - $210
Red = Required
Orange = Optional
Blue = Link To Product
Dupont Pin Crimpers. These are 100% necessary Of course and are used to Crimp all Kinds of Pins onto the Wire.
Link to the One I Use:
https://www.amazon.com/Zhushan-0-25-1-5mm%C2%B2-Insulation-Terminals-Connector/dp/B086YG8NQB/ref=sr_1_3_sspa?crid=1TYA9GFW5PMMN&keywords=dupont%2Bcrimping%2Btool&qid=1662486141&sprefix=%2Caps%2C40&sr=8-3-spons&th=1
Manual Wire Strippers + Auto Wire Strippers. You will Need Both if you are making Modular Cables that Include Double/Split wires within their Pinout. The Auto Wire strippers are for Stripping the Ends of the Wires to crimp pins on. The Manual Wire Stripper tool is for My technique (aka the Best Technique) of making the Split Wires more Detail on that Later. Links Here:
https://www.amazon.com/Self-Adjusting-Stripper-Klein-Tools-11061/dp/B00CXKOEQ6/ref=sr_1_6_mod_primary_new?crid=3NH2TT13R2TPP&keywords=wire+stripper&qid=1662486561&sbo=RZvfv%2F%2FHF%2BO5021pAnSA%3D%3D&sprefix=Wire+s%2Caps%2C74&sr=8-6
https://www.amazon.com/DOWELL-Stripper-Multi-Function-Tool%EF%BC%8CProfessional-Craftsmanship/dp/B06X9875Z7/ref=sr_1_12?crid=3NH2TT13R2TPP&keywords=wire+stripper&qid=1662486561&sprefix=Wire+s%2Caps%2C74&sr=8-12
Fine Side Cutters + Scissors. These are Simple and pretty Self Explanatory. It doesn't matter much what brand you get here just make sure they are decent quality.
Flameless Micro Torch or Generic Lighter + Butane. These are for Melting the Sleeving to Bind it to the wire. If you are making your cables to the perfect Length you'll Probably be making half the cable outside of the Case and then installing the cable in the case and Finishing the PSU end of the cable in the case. In order not to melt the paint on the case you'll want a Precision Flameless Micro torch and use the Heat Shrink Melt Method. The Flameless micro torch is also Best to use if your chosen sleeving is A nylon Based PET. The generic Lighter is for melting Paracord to bind it to the wire.Link to the Flameless Micro Torch:
https://www.amazon.com/OTC-4470-Butane-Powered-Flameless-Micro/dp/B00JF5T7C8/ref=sr_1_2?crid=1LSBBOQQFD6WE&keywords=flameless+micro+torch&qid=1662487564&sprefix=%2Caps%2C160&sr=8-2
Soldering Iron + Helping hands. It's Important if you plan on doing this a lot to spend a bit more for Good quality. But Most importantly for the Soldering Iron get one That has an On/Off switch and a Stand. Links to what I use Here:
https://www.amazon.com/8586-Soldering-Station-Digital-Display/dp/B07Y7BNQ2F/ref=sr_1_14?crid=3DOQKY9D903EF&keywords=soldering+hot+air+station&qid=1662487816&sprefix=soldering+hot+air%2Caps%2C115&sr=8-14
https://www.amazon.com/Neiko-01902-Adjustable-Magnifying-Alligator/dp/B000P42O3C/ref=sr_1_5?crid=R9V8P0IE5G09&keywords=soldering+helping+hands&qid=1662487890&sprefix=soldering+helping+hands%2Caps%2C80&sr=8-5
Silicone Soldering Mat. This is a Heat resistant Soldering Surface That protects your desk from Soldering This is important, especially if Soldering on a Potentially Flammable Surface like a Wooden desktop. Link here:
https://www.amazon.com/Hengtianmei-Insulation-Silicone-Position-Soldering/dp/B08V4YPJZN/ref=sr_1_2_sspa?crid=12OIDJ5J2LKDP&keywords=silicone%2Bsoldering%2Bmat&qid=1662488157&sprefix=%2Caps%2C140&sr=8-2-spons&th=1
PSU Tester. Early on when new to Custom cables I HIGHLY recommend you get one or two of these PSU testers They will save you if you make a Wiring mistake. You Might Destroy a PSU tester early on However They are only $10 USD and it's better to part ways with one of these than to Potentially Kill A GPU, Motherboard, CPU, HDD, SSD, etc... Please Invest In one of these because they are a Lifesaver For beginners and even Experts. Link here:
https://www.amazon.com/Comidox-Computer-Supply-Tester-Automatic/dp/B07J9LRC6T/ref=sr_1_8?crid=1ZRFWAFDEDWM1&keywords=psu+tester&qid=1662485852&sprefix=Psu+tes%2Caps%2C132&sr=8-8
Digital Multimeter. This is an obvious must-have for an electrician and it is a valuable tool for this use case, however, it's technically not required if you can't stretch the budget by $20-$40. There is a $10 option on Amazon but I cannot vouch for the quality as I don't own it. Links to the cheapest one and the one I use:
https://www.amazon.com/Plusivo-Digital-Multimeter-Measuring-Resistance/dp/B086Q4PKYT/?_encoding=UTF8&pd_rd_w=4mzXP&content-id=amzn1.sym.8cf3b8ef-6a74-45dc-9f0d-6409eb523603&pf_rd_p=8cf3b8ef-6a74-45dc-9f0d-6409eb523603&pf_rd_r=V3G4PJECAHMNMFTPR5B2&pd_rd_wg=2OmUg&pd_rd_r=a88ad583-f891-4932-8bda-1695c3961662&ref_=pd_gw_ci_mcx_mi
https://www.amazon.com/AstroAI-Multimeter-Resistance-Transistors-Temperature/dp/B071JL6LLL/ref=sr_1_20_sspa?crid=GGPFAPTK6QZ2&keywords=digital+multimeter&qid=1662660043&sprefix=%2Caps%2C39&sr=8-20-spons&psc=1
Red = Required
Orange = Optional
