I have to say temps are better than I expected, I was afraid this card was going to be a small furnace.
sorry i am a newbie to this forum
i reserved 3 holes for an external loop when go watercooled-aircooled hybrid
it is a little ironic that a triple AMD plaform using Nvidia Titan style venting holes lol
and there will be a custom FPC cable connect to the pcie riser card to tranfer pcie signal:
@Lupercal
Very encouraging results! Thanks for taking the leap and sharing with the community. I’m curious to see what clocks the card is holding. In my experience anything 74C hit the one I had pretty hard.
The Omen power brick seems legit.
Yes. I am pleasantly surprised!
Fan-tastic! Can you please let me know where this blower can be sourced from? Thanks!a single 11cm big 12mm thin powerful blower....
Check this:Fan-tastic! Can you please let me know where this blower can be sourced from? Thanks!
This is great! ThanksCheck this:
Delta is Thicker one of 25mm,sunon is in 12mm thickness .i think they are used in AIO cooling,both can be either silent or...violent lol
There are alot of amazing modders out there (and we have several on this forum.) Guryhwa is my favorite hands down.
AMD will probably start getting bored soon and decide to sell a 2-GPU Vega 128.Or just let me borrow one for a couple weeks and I will send it back in (mostly) non-melted condition.
Very well-done! You should see the size (and weight) of this heatsink from my Pentium 4 PowerEdge: https://www.flickr.com/gp/165204374@N04/5FU7TjOn another note the temps on this bad boy really are not that bad as long as you can get ample air to breath. The VEGA56 NANO in my Dr. Zaber Sentry in the vertical position running 4K games has my temps around 65c-70c at full load. Not too shabby. The issue is when you have that chassis in the horizontal position with the fan facing the floor with minimum height clearance for fresh air.
An open test bench experienced the sa,e temps of around 60c-70c at 4K level settings.
Superposition Score on my test bench: https://benchmark.unigine.com/results/rid_d2434d4024ed4ccdb0618294c34c3883
Benchmark say's "HIS" brand, it's not. I guess it's not marked correctly globally atm.
Firestrike Score compared with a 2400G | 1700X | VEGA56 NANO | VEGA64 Limited Edition:
https://www.3dmark.com/compare/fs/15712325/fs/15695132/fs/15706548/fs/15528231#
It is heavy AF for something the size of the palm of my hand!
Is it Simple to remove Only the fan shroud or we have to remove other things before?
Sadly, it's not vapor-filled and it's not very fin-dense either...Now that's one wonderful looking copper heatsink. if that can fit on the Nano with minimum modding and attaching a blower fan with cfm of the gods then that would be an interesting mod for sure.
