Hey All,
Decided to post this since it turned out great and has parts that no many Ncase folks have played with in combination. Recently decided to try my luck with taking apart my EVGA 2080 Super Black and putting an Accelero III on it, which is not supported. I can confirm that it works extremely well and just 'barely' fits into the case. Front I/O wouldn't be fun to route and would cause a lot of issues with fitment, so I left it out.
- Rear intake fan is a 92mm Arctic, that performs very closely to the brown 92mm Noctuas and looks a hell of a lot better
-Thermalright Silver Arrow configured as intake with the stock fan - it performs pretty well and looks/fits much better than trying to smash in a square Noctua 120
-GPU fits super flush with 120mm Noctuas as exhaust
-9900K CPU clocked to 4.9 and stays around 90 degrees under crazy load, but around 70-85 in normal high-load situations
-GPU tops out at 73 degrees pushing out max graphics at 165fps, with Noctua fans at max
-Noctua 120mm exhaust fans are very quiet at full load
** Key thing to note - the 14pin adapter that converts RTX fan headers to standard GPU fan headers does NOT work correctly in terms of fan curves ** It basically runs at full load or super minimal load, with nothing in between. I ended up purchasing Argus Monitor and it works like a charm with the case fans tied to the GPU temps.
I put heat sinks on everything that contained thermal adhesive strips from stock setup, so VRM and RAM I guess
Hit me up with any questions.
Ncase M1 V6
Ncase M1 V6
