I am building a system with 2x USB3 ports in the front and have found the 20/20 cable to be a pain in terms of bulkiness and lack of flexibility. At least, they should be made with silicone insulation to make them more flexible. Also, the latching of the connectors is also a pain. Couple that with the housing of the connector on the chassis side is loose, so for now I have removed it. I may or may not use crazy glue to put it back on the power push button / USB ports assembly.
The case is a MX500 and the motherboard a B450 Gaming ATX/AC from ASROCK. The two connectors, chasis and mobo header, are next to each other about 2" apart. The cables end up looping over the CPU cooler. Not good.
I find it so annoying that I may look for a compatible cable to downgrade to USB2.
