Hello
My aim is to build on A4-SFX v4.1 using AM4, but I cannot find many mobos that support USB 3.2 gen2 Type-C, so I could use front panel USB C.
Only one I found is Asrock B550i Phantom. Other B550i's only gen1 and Gigabyte null.
1. Is Type-C gen2 plug backwards compatible with gen1 header? Will it work if I connect it but with slower 5 Gbps speed or it won't work at all?
2. Will adapters compromise speeds or voltage?
3. Will adapters fit in this case?
4. On dan's website they recommend to buy low end mobos and save some money for GPU. I would like that, but which boards I could use that can still let me utilise full functionality of the front panel USB Type-C gen2?
Thanks
Thanks
