So, I bought the LZMod A24-V5 gray case a few days ago on AliExpress & they currently show delivery in about 9 days.
Looking forward to receiving it (I love all metal cases, especially aluminum & hate plastic of any kind on cases).
Reviews I've seen online show it has very good build quality & I love the internal layout, with the PSU mounting in front, support of 2 80x10mm fans on one (top) side, and all the ventilation holes for airflow. I intend to use the case horizontally, laying flat on my desk.
I also love AMD APU's & intend to use this case with the lowest-priced B650 mobo that supports 2 M.2 SSD's with an upcoming, soon-to-be-released Ryzen 7000 series Zen 4 desktop APU (7700G?) . According to online rumors, these APUs are due to be released "Very Soon". REALLY hope so.
With that, I'm wondering about a couple of cooling-related things for this upcoming build:
- Can anyone recommend good 80x10mm fans for this case & possibly where to buy them? I've looked online & haven't been able to find any.
I plan to use at least 2 in the right side of the case (when case is laying horizontal) & possibly 2 more on the left side of the case (next to the PCI-E slot of the motherboard)
I will most likely be adding either a 10GBE NIC in the PCI-E slot or a PCI-E to M.2 card to support an NVME SSD.
- Wondering about the direction of the fans for this case. I originally thought the fans on the left side of the case would blow into the case & the fans on the right would exhaust, but I've been toying with the idea on having 1 fan on each side as intake & 1 as exhaust. I've never actually tried doing this on any builds I've done & am wondering what kind of cooling results this would provide?
- The APU/CPU cooler I'll most likely use is the Thermalright AXP120-X67, since including fan it has a 67mm height & this case supports a max. of 69.7mm, though wondering if 2.7mm is enough to avoid turbulence in this case.
Almost forgot to mention - for PSU, I'll be using the HDPlex GaN250 I already own, mounting to the front of the case (double-sided tape anyone? )
Any thoughts? Thanks!
