So this thread is a mainly a discussion about unconventional PC cases that make you think/say "They put a PC in that?"
For example, the Lego PC case made out of lego, or a PVC pipe skeleton open air case, or even mounting laptop parts in a pizza box.
I've seen people scoff at the "trash can" PCs that major manufacturers were making in the early 2012s, but why not build one in an actual trash can? You can cut holes for extra ventilation and the i/o shield.
Eh, but on second thought, while you could do that, unless it was a metal trash can, you would suffer from structural integrity and it just wouldn't look great? Besides, using a trash can as a pc case just seems weird and impractical.
After all, if you're going to use an unconventional case, it has to be at least practical. If you can make it stylish, then that is another plus.
Now, you've probably heard of making a case out of a pvc pipe skeleton frame, such as this ITX build, but what about inside an actual 10" diameter pvc pipe? I guess probably because a PVC pipe that big is hard to find and not readily available. But, I think it would make a cool case, just stick a large fan on each end and have the air flow through from one end to the other.
There's actually some manufacturers and plumbing supply companies near where I live that make larger size pipes and one actually makes clear plastic/acrylic tubing that I could use. I'd just have to come up with a metal frame that would slide in and out of the tubing.
What are some unconventional pc case ideas you've had in the past?
