I've recently transplanted my 11900K/3080 from my FormD T1 to an Ncase m1. Blessed to have bought the case on a whim one day only to find out weeks later that the case is no longer available. The story begins with loud fans and very warm coolant. I had a TX240 with three Noctua NF-A12X15's and a DDC pump mounted to the top of the case. It was a temporary solution but one that never got resolved due to the mounting concerns of my temps. I undervolted my 3080 heavily in an attempt to tame the thermal beast and with my 11900K in similar shackles, I was not content. WHY can't I push my components to their limits?! WHY must I suffer the oppression of undervolting and power restictions. All while being besieged by an audible onslaught just to keep it functioning. My discontent had grown beyond my wallets ability to fend of the pestering of a larger case with more cooling options. An Ncase M1 was bought and a second 240mm rad was thrown in for good measure along with an iceman pump res combo...
Yeah look nothing really changed a great deal. I got a little more headroom with my 3080, but my coolant temp still clock out at 55 degrees after an hour of New World and even with fans pumping I'm still not convinced this is the solution. I'm going to use a CPU block/pump and throw a third radiator onto the back to see if it will help. (With a 12900K on the way the outlooks not great).
So my question is does anyone know of a layout similar to this?
It's the M1 layout with room for a 45mm thick rad and 25mm fans on the bottom. 25mm with 25mm fans on the side mounted rad. I was also toying with another 240mm on the top with a TX240+15mm fans.
Does it exist?
Does it exist?
