Hello,
I have this motherboard :
my idea is to feed the mother and gpu with the source and maybe add liquid cooling. Only that I have many doubts if with the mother I can use the card natively so to speak or use an adapter.
Thanks a lot
ASRock Industrial IMB-1215 : Amazon.com: ASRock Industrial IMB-1215 Intel 8th/9th Gen Core Q370 Mini ITX Placa base, Triple DisplayPort, Dual LAN : Electrónica. and I would like to use it, my question is if this motherboard supports gpu : GTX 1060ti and if it is possible to use a psu flex : Amazon.com: FSP Mini ITX Solution/Flex ATX 500W Efficiency ≥90% Full Range Active PFC Power Supply (Flex Guru 500W) 500W unidad de fuente de alimentación : Electrónica to power the motherboard and the gpu.
Thanks a lot
