Hi,
First time posting here, but read a few threads here to know that if there is somebody who would know the answer, it's someone here.
In short, I'm building a PC inside of a Gamecube (link to my build log on the L1T forum). My plan is to use the ADT NVME to PCIE Adapter Card to connect a GPU to my PN50. A PicoPSU is used to provide the necessary current to the adapter to power a 1650 through the PCIE slot. The PicoPSU is plugged in a Add2PSU in order to sync the power on.
But here's lie my problem. To my understanding, the Add2PSU syncs with the 12V signals. I assumed that the fan connector on the PN50 had a 12V lead, but I just discovered it doesn't have one. The highest voltage on any connector on the PN50 is 5V. And I try to sync with 5V maybe but to no avail.
So do you have any recommendation to power and sync a GPU with the PN50 because right now I'm kind of lost.
Thanks
Thanks
