Trading Swap? Need A Longer Riser..
I got the ModDiy 9cm riser and changed my mind on the design....
I want to lay the card flat, fan facing up (Its a blower type 1080ti) so that means taking the riser under the board and running the card opposite side of pci slot, or running the card on the same side of the pci slot and doing a "180" with the card.
Anyone got a riser laying around and wants a shorter one? :-)
Biowarejak
Maker of Awesome | User 1615
1,744
2,262
I have a fairly long riser I could trade :) Would need to open up my rig to get the length though, won't be until a few days - when my motherboard arrives.
Reactions: Todayican2
Biowarejak
1,744
2,262
It's like 8in long and a straight connector on both ends. Insulation is also peeling a bit towards the connectors from how many times I bent the whole thing. Probably better just buying new, it was like $20 at Fry's
Biowarejak
1,744
2,262
No problem :) will say that the brand has worked for me without issue. If you need a specific length though I'd measure that with a piece of string and order it from one of the usual suspects if it isn't close to a standard length you can find available
