A couple years ago I posted a thread about the Eblaztr. In short, its a portable AIO case with a monitor vesa-mounted to the side panel with extendable legs.
Does anyone know of a case or case mod that does something similar? If not, I was thinking of making or modding my own case.
Main reason is I'm not going to get the Eblaztr because its too expensive($449). I feel I can buy a metal box, drill the necessary mounting holes and mount a monitor to it and I would pretty much have the same thing. Either that, or I would buy an existing case, and replace one of the glass side panels with a monitor. This will probably take months to plan and create, so its still very much in the design stage.
