Suggestion on my build?
bleed
21
www.artbleed.com
Hey everyone! I'm stuck on deciding what GPU i should get. Wondering if I can get some suggestions please!
I'm a designer and my main use for this setup is digital art, 3D and Vid recording. I occasionally play games but not any high demanding titles. (Overwatch etc).
I currently use 3x 1440p monitors (2x60hz & 1x144hz).
I am upgrading my whole set up this month and my build will be -
Ncase M1
Ryzen 9 3950x
NZXT Kraken X52
Corsair SF600 Platinum 600W
ASUS ROG Crosshair VIII Impact
G.Skill Trident Z Neo 32GB 3600MHz CL16 DDR4
I really want to save money by keeping my current GPU (EVGA GeForce GTX 980 Ti HYBRID GAMING) But i cant figure out anyway to fit the 120 aio without sacrificing the X52.
So i guess the next option is to buy a new GPU around the $450ish mark, but basically something that I can still use to game at 1440p.
Should I get the 1660 super? Or look into RTX?
I hate myself for buying an aio GPU ?
Cheers!
HyperActive
183
75
Well, when you mention 3 monitors at 1440p, only thing that comes to mind is a rtx 2080ti. A 3950x is very expensive, so why not go all out too when you basicly got no budget?
Reactions: bleed
tinyitx
2,279
2,338
If you are happy with your current 980Ti as far as gaming goes, then a 1660 Super might not provide similar experience as it is weaker. With a 450ish USD budget, a 2060 Super is a better choice.
Reactions: bleed
bleed
21
www.artbleed.com
Maybe buying an Accelero III would be cheaper than buying a new gpu? Or buying a "for parts" 980ti off ebay?
Oh man! I never thought of modding my current gpu! Thanks! Gives me more options to think about now. :)
Yea, im afraid that it would be a lot of difference with the 1660 Super. There's currently some awesome deals for the 1660 super though (around $320aud) which im considering. Just hope it wont be too different. Either that or ill look out for a 2060 Super during christmas. Thanks!
But having 3 1440p monitors would only matter if i game on all 3 at the same time yeah? I definitely have a budget, as im stretching it already. I only need to upgrade due to work. GPU is secondary for now since most of the programs I use is more CPU intensive. Would love to go a 2080ti though haha~
