A while back I bought a Sugo SG13 and modded to host an SFX PSU. I thought it was a good idea at the time but it turned out that the PSU I have (a semi-passive corsair) heats up A LOT and I ended up with a pretty hot rig despite I could place a bigger fan on the CPU.
So back to square one. I took some measurements and it looks like I can put the PSU on the front of the case... and actually I could go as far as using a full size ATX PSU. Doing so I would also have a full popping 160mm available height for the CPU cooler. This is something I HAD to try!
The components:
- Seasonic ATX PSU
- Noctua c14s CPU cooler
- MSI Aero 1060 (mini GPU)
- Asus strix z270i motherboard
- Samsung 960 pro M.2 SSD
So basically:
Challenge accepted!
I'm sure someone already did something like that, let's see what I can do I just hope everything actually fits
First step is to find a way to hold the PSU in place. On the bottom there are 4 very cute holes for an HDD I guess. I can put them to good use!
All left to do is to design a support for the PSU that holds on those 4 screws. I ended up with this design
To the 3D printer! See you later and wish me luck.
The components:
- Seasonic ATX PSU
So basically:
Challenge accepted!
