Elon Musk has gotta be one of the happiest men on Earth right now, first the Tesla Model 3 pre-orders are off the charts and now SpaceX has successfully landed a first stage out at sea after several spectacular failures.
The first Grasshopper was a F9 ('v1') first stage with all but one engine removed, and some fixed landing legs added (and a bunch of ballast to keep the TWR down. And a cowboy). The next (sometimes called F9R) was an F9 v1.1 first stage with 8 of the 9 engines removed and the landing legs fixed in place. The final grasshopper, intended for high-altitude tests, was cancelled after the successes in high altitude stage manoeuvres starting with F9 V1.1. This triple-engined core is rumoured to have been mostly constructed, and may be used as the in-flight-abort boost stage during Dragon 2 testing.Man I remember when they did tests for this with the Grasshopper rockets. That thing was so cute compared to the Flacon.
The timestamp you're looking for is 29:14. Very cool that they managed to do this first try!
Well, second try. First try with the triple-engine landing burn and no boostback burn was with SES-9, which left a hole in the ASDS.
The triple-engine burn is interesting: it starts with with all three engines ignited, then the outer two shut down so the final hoverslam is performed on only the central engine. The reason for doing a triple-engine burn rather than using just a single engine for three times longer is gravity loss: the longer you are firing for, the more time you are spending fighting gravity. This means you use less fuel burning harder for less time.
