So I'm running a FURY X with a 400W SFX PSU
this one: KRPW-SX400W-90+ (80plus gold)
as you can see the psu only have 1 6pin, the card requires 2x8pins
but I was confident it can run fine with an undervolt (1000/500 - -95mV), so I use an 6 => 8pins adapter, a 1 to 2 molex adapter and a 2x molex 4pins to 8pins adapter. (Yes I know, stupid me)
the computer ran fine for about a week, then this morning when I game for 20 mins the computer black screened. reset. relaunched game, still black screen. I disassemble the box and the 12V pin on the molex burnt a little bit
Q: should I continue to use the SFX PSU? if so, which is better? 6 to 2x8pins adapter vs a 2x SATA to 8pins
Using a 6 to 2x8pins adapter means 3 yellow cable
Using a 2x SATA to 8pins means 5 yellow cable (the unit have 2 sets of sata cables)
thanks alot for reading
