Power Supply Smallest external 80w AC-DC (19v) adapter?
GentlemanShark
Asus RMA sucks
Marsupial Computing
Dec 22, 2016
358
148
I'm looking for a tiny power adapter to use with this build, it shouldn't draw more than 80 watts so a smaller adapter should be possible, right? Any suggestions for a tiny one?
KMPKT
3,382
5,936
Have you considered going internal with the HDPlex 80W AC-DC?
GentlemanShark
Asus RMA sucks
Marsupial Computing
Dec 22, 2016
358
148
I have, but it would take up a lot of space and it would look odd if there was a power cable going to it (case inside a PC component)
Lone
Lone Industries
Feb 25, 2015
731
1,249
loneindustries.com
You shouldn't have any problem using a 60W external AC adapter with that build. But, if you don't need the absolute smallest AC adapter, then 80-90W is preferable.
Lone
Lone Industries
Feb 25, 2015
731
1,249
loneindustries.com
For 12V, I've used the 60W that Mini-Box.com sells, but it's not the smallest option. For 19V you could look at some of the slim Dell AC adapters. The FINsix as already suggested is probably the smallest and most expensive option.
