So I recently picked up the Sliger SM580 along with the Alphacool Eisbaer 280 CPU along with the GPU block extension, but I noticed the CPU/pump combo was too tall. Is there an reliable alternative cpu/pump combo that I can swap out?
There is the Eisbaer Solo LT . though a bit harder to get. Linky
and the apogee Drive, though not sure how much smaller than the full size Eisbaer Solo it is.
Other options I've encountered are the Fractal Celcius S24, but the hoses can only be disconnected at the radiator end with G1/4 fittings, not at the pump/block end.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
