So, my head is obviously not listening to me - after snatching one 6800XT, I thought that why not wait for second or third AM5 iteration and now my Ryzen 5900X is traveling to me. Ryzen 3600 is good, but I got the 5900X almost at MSRP, so it wasn't that hard call.
Now, I went through a lot of videos and threads lately and I honestly can't justify any of the compatible coolers over the Wraith Stealth. I don't want to find a way in for Blackridge, so it is out of the picture.
NL9a or IS-47 deliver a bit better but having in mind that I need to disassemble the whole PC and make custom backplate (MSI B550i) for the cooler, and of course, the price, I am not sure if it is worth it. Also I really plan to submerge all of this in custom water cooling SM570, so this is rather long temporary solution. Or even try my luck inside the SM550 on high heels![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So, couple of things I need outside view of:
1. I will obviously run this in Eco Mode. However my board's Eco is listed at 45W. I hope won't need to go that low, so I will need different approach. Is PPT=65W enough? Do it need to touch EDC and DTC as well? Or anything else part of PBO or the advanced settings, so I can achieve Eco?
2. I will undervolt with -offset. Hoping that the board can do it properly.
3. The whole thing will run at the upper range of the temp scale. My 3600 idles at ~50C but I am hoping that this is because of the uneven CCDs. Hopefully I won't kill it soon![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Or all of this is a bad idea? I will be able to return the CPU in 1 month period, so I can always pull the plug, but I hope to get it done.
I am no hardcore gamer or anything and I don't drool over 100fps, so anything above 45fps is good for me. But I do sometimes to things which will benefit core count vs IPC.
Forgot that I don't have the hardware in the signature:
MSI B550i Gaming Edge Wifi
Ryzen 5 3600 [Wraith Stealth]
G.Skill 2x16GB F4-3200C16Q-32GTZR
AMD RX 6800XT
EVO970 500GB + EVO850 250GB + EVO850 500GB
Corsair SF600
Thanks in advance!
AMD RX 6800XT
Corsair SF600
Thanks in advance!
