Production Sliger SV590 and SV540 - Vertical SFF Cases!
Bigtruckboom
21
Are you able to close the case without any problems (because of fittings)?
Did you tried an EK pump top and short tube in the meantime?
Could you please tell me your tubing between your components - e.g. radiator > GPU > CPU > pump... I would like to know if it's better to install a cpu block with in/out one above the other (e.g. Aqua Computer Kryos) or side by side (EKWB)
Thanks!
No issues closing the case, had to shorten the tubing run from res to cpu from what is shown in the pictures but all panels line up flush with no bulges. The top panel does not close all the way as the 420mm rad is too tall to allow the power cable to fit through the passthrough. I have not tried the ek pump yet, the Bitspower D5 RGB top will allow the Bitspower Multi-Z 40mm Reservoir to thread directly on and is the smallest D5 pump/res combo out there and should fit no problem, I just haven't gotten around to installing it yet. Tubing goes from Pump >GPU>Rad>CPU>Res. I couldn't tell you what water outlet order is preferable.
Reactions: UdoG
kanxkeri
Case is designed to pull air in through side vents, and exhaust out the back of the case, so long as you use it that way your temperatures will be good.
So after reading this comment, I went back to have CPU fan (Noctua A9x14 HS-PWM Chromax) blow toward the heatsink and have all 3 Arctic P12 fans have it exhausted.
This way, able to hit 65C CPU / 42-44C GPU (RTX 2080 w/ Arctic Accelero III + 2 A12x15 Chromemax) when playing MHW:I compare to previous setup hitting 75C CPU / 45C GPU and loud CPU fan noise. This further reduces the noise and no turbulence issue I used to see using the stock fan of AXP-90 as well.
UdoG
26
Thanks for your feedback. Could you please give us an update as soon as you installed the Bitspower D5 RGB top with Reservoir? Maybe the 80mm Reservoir will fit too :-). Which D5 did you buy - a PWM version to control it via the mainboard?
Bigtruckboom
21
So in my setup, I have about 160mm of length, 70mm of width, and 130mm of height to put a pump and res in. Width is obviously the most limiting factor. The D5 pump is about 30mm long, and the pump top is 70mm in length and width, and 49mm in height. Combine that with an 80mm Res and youre cutting it close, gonna have a hard time positioning your fittings, at least in my build. i'm going with the 40mm res just so I can have a little bit more space to work. I used an Ek PWM pump, because it was easily available on amazon, although the vario pumps would be better as you can just set the speed and forget it and less cable clutter. The EK does have sleeved cables for what its worth.
Make sure if you go the bitspower route to get the RGB top, it's the only one that will allow the Bitspower Multi-z tanks to thread directly on. Otherwise you can attach the Multi-z take to the pump top with a male-to-male adaptor, but it looks ugly, adds another point of failure/leak, and makes the overall assembly longer.
Reactions: UdoG
UdoG
26
Thanks for your feedback!
So the length of the GPU/waterblock limits the height of the pump/res combi?
Then you would have to check with every new graphics card whether everything still fits :-/
Bigtruckboom
21
The graphics card isn’t a big problem, the main issue is the width from the case wall to the power supply. You really only have about 70mm of space there. Most graphics cards aren’t that long with a water block on them. Maybe the custom pcb cards are but I’m just using a reference pcb.
Reactions: UdoG
UdoG
26
Thanks. My 590 will delivered today or tomorrow. So I can start with by build.
I will try if my D5 NEXT pump will fit, but I think that will be not the case.
UdoG
26
Another question - do I have an issue when I use a WLAN adapter (2,4GHz) for my keyboard and gamepad? Maybe the case will disturb the connection/quality of the signal?
Bigtruckboom
21
Why you didn't install the fan/rad as intake? You will have more space for cables (top) and maybe better temps. Is it due to dust?
I'm not following you. My rad is mounted as intake, the fans pull air from outside through the rad into the case. The fans I'm using (EK Vardar 140mm EVO) perform slightly better in pull according to the manufacturer. I'm thinking about running the rad as an exhaust and seeing how it performs.
Insomnium
I thought the optimal configuration for sv590 is for the Rad Fans to exhaust air out of the case and let the air be sucked in from the side panel? That's what I'm doing.
KSliger
855
3,186
This is correct - if the fans blow into the case they can cause problems with the PSU and GPU cooling.
If you're on a custom loop the GPU doesn't matter, but I'd be wary of torturing your PSU with high temps.
I'd also recommend putting the PSU fan towards the inside of the case to pull air from behind the GPU - made a few degrees GPU temperature improvement in my testing.
Any news about SV540??
Waiting on news out of China on PCIe risers and power switches.
Honestly looks like they went back into lock down as I haven't heard anything today, cannot contact any of our vendors.
Might not be good.
If they do drag this lock down out we will probably go on backorder for existing cases, and put up a bunch of new preorder cases.
Have another 2-3 weeks before we have to start thinking more seriously about that.
Without getting too technical, no you should not have any issues or signal degradation.
The only thing you could do wrong is if you have a higher gain (8dBi+) antenna that can be bent over and you fold it over so that your wireless AP or Keyboard/Gamepad are in the vertical dead zones. Best to go with a low gain (2-4dBi) stub antenna if you're in a smaller apartment, or an externally mounted mid gain (5-6dBi) if your AP is really far away such as a larger house or office.
Either of these should be viable work around at 2.4GHz if you want to play it safe, these look like best value on Amazon for respective purpose:
Reactions: UdoG
Insomnium
Watching the new NZXT review I realized i have the same problem with the GPU where the front panel is kinda hot after a few hours of gaming, is that normal? GPU temp is around 70 celsius while cpu is at 60-65
UdoG
26
@KSliger
I have some trouble with the SV590 case - especially with the paintwork: the paintwork is bad on several sides (always in the lower area. I already sent a mail last week to the Sliger support - since today no feedback. So I sent a second mail today... Maybe you can assist me? The case is not really cheap and the quality has to be good.
Here are some pics:
KSliger
855
3,186
@KSliger
Here are some pics:
Sorry on no response yet, we are perpetually buried on emails.
Few posts of mine back I put that if anyone isn't happy with their rust we will replace it, as I was concerned about a few of these.
Reach out to me, [email protected], and I will send you a new panel set in rust with better bottom ends, or in any other color + $50 refund.
We had a few of these where the rust ran down the case panels during the bake cycle and resulted in these odd bottom ends, this one is certainly one of the worse ones. Picture IMG-3863 should not have passed QC at all - those with bubbles were supposed to not get clear coated but might have bubbled when the clear coat was baked.
Very sorry on the problems, will get it fixed for you!
Reactions: Allhopeforhumanity
