[cross-posted from builds, this seems like a better place to get responses, hope that's ok]
Hi,
I've ordered an SM550 case, (specifically over the SM560 because I wanted a slimmer one).
I'm now trying to work out what the widest card I can fit in there would be
practically speaking. In
theory, the specs for the SM550 give the following max size:
- Maximum card height: 133mm
- Maximum card length: 305mm
- Maximum card width: 2 slot, up to 50mm [I note some cards billed as 2.5 slot are <= 50mm]
Numbers are all well and good and there are a few cards with beefy cooling which I'd like to consider based on these dimensions, but first I'd like to see if anyone has actually tried one?
For example, the ASUS ROG strix 2060 has dimensions at: 300 x 132 x 50 mm
This is
theoretically within the case tolerance, but does it
really fit?
Since I opted for vented sides, and the holes are very generous, I'm thinking the lack of gap between the card fans and the case wouldn't be a deal-breaker...
Thanks!
